save model in different folder
Hello All,
I run model in past means before 5 day (today-5). when simulation reach at current time(Now). then we get new order.and this new order we can produce by different layout(change position of station,,assume that we have 5 layouts). we want to simulate all layout and then check which is optimize layout.
concept:: when simulation reach at current time then  we want to save this model in different 5 folder and then we will run this models manually (from different 5 Folder) and take statistics and we can easily find optimize layout for new order.
Que:: when simulation reach at current time then  we want to save this model in different 5 folder. But How?? Is it possible to save model in diff folder by  simtalk???
plz suggest me any idea to solve this.
Thanks in advance
Re: save model in different folder
Please have a look in the help file
for saveModel under Miscellaneous Global Functions
Hi @simulator
thanks for your reply. its excatly what i want.
i have one more question. After saving this model in dfferent 5 folder.  Is it possible to  run automatic these all model from last position(last position means from when excatly it was saved (( with all call chain,suspended method,same position of worker and everything....)).
thanks a lot in advance
Please read the help file
thanks @simulator
i understand..i have onemore que: is it possible to run model automatic(after saving). Is there any code available in simtalk?
thanks in advance
Have a look at the autoexec - and eventcontroller.start methods
