separate string
I have input in the attachment and it should be inputed to the shift calender..
Its only one string in a cell of excel and inputed to plant simulation through readexcel method into table file
tablefile.readexcel("string.txt");
Please let me know how can i do it..
Re: separate string
Hello Amar,
your string does not contain the necessary data for the ShiftCalendar object.
Insert a Variable object of type table and read the shiftPlan of a ShiftCalendar object by the following instruction:
Variable := ShiftCalendar.shiftPlan
You will understand the structure of the shift plan.
Then you must extract the data by string functions, like
str := copy(str,pos("Pause",str)+9, strLen(str))
str := omit(str,strLen(str)-1,3)
variable[11,1] := str
ShiftCalendar.shiftPlan := variable
Peter
Re: separate string
Thank you!
Amar Singh
