single part run stucks
i want to calculate how much time a single model in my assembly line will take to reach drain . but it stucks in the middle i can't find whats the issue
Re: single part run stucks
you use in line2 the setting "GAP" and a positive value. This means, that the MU on the line waits until the next MU is arriving to "create" the gap. You produce only one part, so this part is waiting and the simulation stucks.
Use minimum gap instead, this allows the MU to continue without direct following MUs.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
