standby machine- job shop
Hi community!
I'm having a problem with job shop system.
i want to put the machines in the standby state and then in the operational state.
for example, SingleProc1 has to go to the standby state when its buffer is empty and the other machines finish to work in more than 1 minute. Then SingleProc1 has to go in the operational state if there is a job in the buffer or the other machines finish to work in less of a minute.
I wrote a method in the entrance and in the exit control but it doesn't work and the simulator tells me that the problem is the remaining process time.
Can you help me?
Thank you!!
