store arrays inside an array
Builder
Builder
is it possible to create an array to store arrays?
example:
is
array_A: string[];
array_B: string[];
array_Master: object[2];
do
array_Master[1]:= array_A;
array_Master[2]:= array_B;
end;
Re: store arrays inside an array
you can use the method makeArray to create your array e.g.
is
	array_A:string[];
	array_B:string[];
	array_Master:any;
do
	array_A:=makeArray("one","two");
	array_B:=makeArray("three","four");
	array_Master:= makeArray(array_A,array_B);
	print array_Master[2][1];
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
