syntax error Method inspect @. name
I have syntax error for method inspect @. name
In the model from source i want to send object a, b,c to different line using Method.
But the method shows an syntax error.
Please anyone can suggest the solution for the problem.
Re: syntax error Method inspect @. name
Honored Contributor
Honored Contributor
you need to switch off the new syntax in the tab "Extras". In the new simtalk syntax inspect is replaced by switch - case.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
switch @.name
case "a"
@.umlagern(l2)
case "b"
@.umlagern(l3)
else
case"c"
@.umlagern(l1)
end
I have written this new code with  switch but still no result
Honored Contributor
Honored Contributor
after else you must not define a new case
attached you find the two variants
Steffen Bangsow
web: www.bangsow.eu
Thank you..for quick solution
