the Transporter move in x axle、y axle、z axle
as below shown,In HBW examples,the Transporter move in x axle、y axle、z axle,I want  to know  how I can realize this result( move in x axle、y axle、z axle).thank you very much
8 REPLIES 8
Re: the Transporter move in x axle、y axle、z axle
this is done by (for example):
  • TransporterX moving on a Track
  • TransporterY moving on TransporterX (Loadbay Type set to Track)
  • TransporterZ moving on TransporterY (Loadbay Type set to Track)
you may check this by View Structure of a model containing a RackLane (after initializing):
2018-05-03 10_12_41-NoName.spp - Tecnomatix Plant Simulation 14.1 - .Models.Frame.png
Always consider using the AttributeExplorer!
@Eventdebugger   dear   why my model  does not hava your structure   as below shown
you did not initialize it before showing the structure (alternatively you can refresh the structure view after initializing the model)
@Eventdebugger  dear  I Initialized the model  as below
I'm about to clarify why you don´t see the + in front ... I´m not sure, but it might be a problem resulting from windows country settings ... just as a first guess
does the + (Expand Tree) left besides the - work?
the + (Expand Tree) dose not work
what kind of license do you use?
I assume you to use V 13, there the HBW-library was still encrypted which is preventing the objects from showing their content, in V14.1 the HBW is not encrypted anymore and will allow you to expand the tree
