the worker avoid the Transporter
as below,in the model the worker is "Move freely within area".   When the work meet the  Transporter,the worker doesnot avoid the  Transporter,but the worker  through the Transporter,how should i solve the problem?
thank you very much!
Re: the worker avoid the Transporter
how about inserting a  barred area (s. 3d help)
around /over the transporter path
or insert some stairs over the transporter path ( s. 3d help)
