Re: transporter control with sensor
one way is to make a small parallel lane only for loading/unloading; split your track in segments and connect all segments with connectors, make a short parallel track for loading, so other AGVs can pass.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
another alternative would be to use a two lane track instead, attached is an example where that is implemented. Would that work for you?
Kind regards,
Igor
