Re: transporter control
thank you for your suggestions. I build the model to research the number of transporters and the transporter load capacity. So I will not add a container. Thany you anyway. I´m still working on it.
you need to change your methods
the decision regarding the destination you need to do in the methods load_Buffer1, load_Buffer2 and load_buffer3 after loading the parts to the transporter; the unload-methods just unload the transporter to the connected buffer
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello Steffen,
thank you very much. It works now!
Liebe Grüße
Dan
