two question about 3D video
hi
when I  record a  video, I meet  two questions, one is that  as below figure it seem that there  is a
light shine the model , when I record the video it will appear  aureole,and the model will has different  colour in different  optic angle
two question is that  the video I recorded ,when play the video some station 3D model  is  swaying,how can I solve  this two questions? thank you very much
Re: two question about 3D video
It took me a while to grasp what you meant with your second question but I think I got it.
A picture as you posted it typically results from a bad video codec which, and I guess, everyone who has successfully recorded a video from within Plant Simulation will agree, the default Microsoft code is. We had pretty positive experience working with the XVid code which you can download freely - just search for it.
This pretty certainly will fix what you describe in your first question.
And I guess, it will "accidentally" fix your second problem, too, which, if I am correct, is simply another symptom of the same problem (i.e. the codec).
