unable to access assembly object in plant simulation assembly line
hi all,
iam new to plant simulation. i am getting a error message when i launch the assembly and overflow buffer object in plant simulation assembly line. please help me..
6 REPLIES 6
Re: unable to access assembly object in plant simulation assembly line
Hi Ibrahhim,
could you please post the model?
Something seems to go wrong with drawing the MUs.
We need the model to be able to find the problem.
Ralf
Ralf
thank you,
here iam attaching my model.. i wanted to place assembly object in between the single proc 1 & 2 in plant simulation assembly.
Hi ibrahim,
I just inserted an assembly station between single proc 1 & 2 and everything runs fine.
Do I have to do something else?
Ralf
Ralf
but iam unable to insert assembly and buffer overflow objects in plant simulation assembly.. iam able to insert assembly station in plant simulation basic but unable to do it in assembly mode.
Hi ibrahim,
thanks, I was able to reproduce your problem.
It has to do with the visualization of the animation points.
Just right click in the frame background and turn off 'Show Animation Points' in the 'View Options'.
Then it's working.
We'll look into this and fix it with the next service pack.
Ralf
Ralf
Thank you so much Ralf.. sorry for the late reply..
