unknown identifier Name
Builder
Builder
hello everyone
I got a problem while running a method in a model, which i am attaching to this message.
it is saying unknown identifier Name and void cannot accept it
could anyone help me please
Please have aa look at my model
best regards
Re: unknown identifier Name
Hello Gopi,
You try to access the 16th MU in the Object Plant_WH but it has only 15 objects therefore Plant_WH.MU(k) returns void and the expression Plant_WH.MU(k).Name leads to the error that a void cannot accept the identifier Name.
Ralf
Builder
Builder
Thank you very much Ralf
what you said is right. But Plant_WH has enough parts of that name (variant_B), why can't it move that part?
could you tell me how could i change my program to get it done.
Best regards
Builder
Builder
It is working now, i added exitloop so that it can't exceed NumMU's.
I have one more doubt that How can we Implement RFID system in plant simulation?
is there any examples You could share with me.
Best regards
A RFID tag just assigns a certain information to a product. You can do the same by creating a custom attribute at the MU, e.g. with name RFID and an appropriate data type. You then can access this attribute at each station and base your logic on the content of this attribute.
Ralf
Builder
Builder
i thought the same but i assumed there may be something more.
Thanks for your time
best regards
