unload container
Hi everyone,
I have a problem with the method of unloading the container in the track. This is what I wrote in the UnloadSenso method (the sensor is placed at the entrance of the track):
param SensorID: integer, Front: boolean
var track:object
var pod:object
var pod_str:string
var b:=1
if @ = .MUs.AGV1:1 and .MUs.AGV1:1.empty = false
	pod:=@.cont								-- check the pod
	pod_str:=obj_to_str(pod)
	for b:=1 to Pod_track.yDim
		if pod_str = Pod_Track[1,b]
			track:= Pod_track[2,b]			--check the track
			@.cont.move(track.location)		-- unload error
		end
	next
end
how should i do?
Re: unload container
the file is uncomplete, if you want help, then you need to post the complete file, we need to see the values in your method
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
