unload object using sensor
 Dear Fellas,
i have a model where the box are are to be emptied to another conveyor.
I have used sensor and NumMu down to 1
problem with this code it unloads only one object not all
any solution to regard very much appreicated
thank you
Re: unload object using sensor
you need to wait inside your loop, until the MU as moved 0.5 meters (0.5 second). To avoid a movement of the container in this this time, you should stop the line during unloading, e.g
if sensorid = 1 then
	?.stopped:=true
	while @.occupied loop
		@.cont.move(Förderstrecke1)
		wait 0.5
	end
	?.stopped:=false
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
