unloading transporter
Builder
Builder
i have a transporter on a track,on the middle end of the track i have a sensor which triggers a method moving the content of transporter to a buffer.but instead of moving all the content of the transporter it only moves one.
method which i have used is
@.cont.move(buffer);
its not working .how can i move all the content of the transporter to the buffer.???
Re: unloading transporter
try a loop for moving all MUs
while @.occupied loop
wait(0.001);
if buffer.full then
exitloop;
debug;--buffer is full, avoid endless loop
end;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Hi Steffen_B
its not working,its again moving only one container out of the transporter.what coulb be wrong??
cont returns only one MU. The buffer needs enough free capacity and the procTime of the buffer should be zero, and use the Buffer instead of the PlaceBuffer.
You can also use the transferstation for unloading the transporter.
Can you post your method?
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Thanks a lot .its working now.
