want to know the function of a command
As you can see in the picture above,the command has been circled.Help...
8 REPLIES 8
Betreff: want to know the function of a command
Hello Riton_Xu,
I don't think that this ribbon is part of Plant Simulation.
Are you sure that you have posted in the right forum?
Ralf
Sorry,maybe tomorrow I should give a bigger screenshot.
And never mind those Chinese characters in the picture,because I use the Chinese version of this software.
To be clear: the screen shot you posted is from Plant Simulation
it is used to edit the routes of the motions
Your screenshot is from Process Simulate. This is the Plant Simulation forum, I'm afraid we can't help you.
Please post your question in the forum for Process Simulate; I think the 'Tecnomatix Robotics Forum' should be the right one.
Oh,thank you.I made a mistake
