worker carry part to store
Master
Master
How to model the worker to carry the container from Conveyor to store and place it in the store?
4 REPLIES 4
Re: worker carry part to store
Hi @SS3
The easiest way is to use a dummy station in the exit of the conveyor. In this station you set the processing time equal to 0 and active the Import > Transport option with the store as the MU target. Take a look at the attached model.
Best Regards,
Paulo Araujo
Master
Master
@araujopaulo  @simulator
Now I have 2 containers in the store with 3 parts in each. I want to assemble all 6 parts.
The first woker job is to pick and placesthe conatiner in store which is happening.
The second worker has to pick the container from the store, place in buffer, assemble 3 parts in assmebly station and keep back the container in the store. Next pick 2nd container and do the same until 6 parts are assembled.
So I added another worker and in the creation table gave service as 'carry'. In the store, importer tab-->transport-->services I gave 'carry'. But the second worker does not go to the store. What is the mistake/?
You will need to move the part from the Store manually with na exit control, then the Importer tab will work.
Best Regards,
Paulo Araujo
Master
Master
@araujopaulo  okay...
