worker simulation
i have 2 stations and material movement them is manual.
one worker has to carry parts between 2 stations.
what are the different ways to model this scenerio?
Re: worker simulation
you could have a look in the example collection, there you can search under "Small Examples" for "Worker" and see different scenarios for a worker carrying parts between stations. There is also a section in the help called "Model a Worker Who Carries Parts Between Workplaces" found in the Step-by-Step help where this topic is explained.
Kind regards,
Igor
1. you can use shiftCalendar to set working time
contact
chs0760@naver.com
