API - GetPartDesign works only for Top Level Part Family
Hi Experts,
I am using the ModelServices API and am trying to get to the Part design file. This works only if the part is a top level part and not otherwise.
Can someone point out as to how to get to the part family design object of a given part?
-Thilak Rao
Re: API - GetPartDesign works only for Top Level Part Family
Can you provide more details about what exactly you need to achieve?
I've some experience with modelservice and maybe will be able to help you.
Adam Liszkiewicz
Configuratori Polska
We got past this and so is irrelevant now.
However I was hoping to get to the definition of a part family object. Siemens PLM folks said that it is not possible to do so and might get addressed in release 9 (major overhaul of the product\API is happening).
-Thilak Rao
