Align to a face in NX spec?
Is there any way to create a constraint that refers to a named face in NX rather than to a plane?
Gene
Gene Libardi
Principal Solutions Architect
Engineering Intent Corporation
www.EngineeringIntent.com
Betreff: Align to a face in NX spec?
Siemens Genius Siemens Genius
Siemens Genius
Hi Gene,
only if you use static assembly. But then the constraint has to be created before loading to Rulestream
BR
Christian
