Global function SortCollection()
Hello
   I am trying to use the SortCollection() function to sort the "SortOrder" column in the DataGridView but I am not having any luck. Does anyone have an example how to use this?
Thanks, John
Here is an example that I tried but is not working:
Dim Quantity As Integer = Me.QuoteDocuments.Quantity
For i As Integer = 1 To Quantity
SortCollection(Me.QuoteDocuments(i).Properties(“SortOrder”))
Next i
Rulestream ETO Version 8.12.0.7556
Solid Edge ST7
Re: Global function SortCollection()
Me.QuoteDocuments(i).Properties(“SortOrder”) is not a Collection, so you can not sort it.
Not fully understand what result you want to get but I suppose that you need to do something like this:
1. To create news connection, name it like SortedQuotes.
2. In the Formula tab you need to write something like.
Dim col_ret As New Collection
For Each item As Object In Me.Subparts("QuoteDocuments")
	col_ret.Add(item)
Next Item
Result = SortObjectsByProperty(col_ret, "SortOrder")
That should be the way to show sorted QuoteDocuments on the UI.
I believe that is your goal.
Not sure that the synthax is 100% correct.
thanks Yuri
Here are my other attempts:
'SortCollection(Me.QuoteDocuments(Me.IndexQuote))
'SortCollection(Me.QuoteDocuments.Properties(“SortOrder”))
'SortCollection(Me.QuoteDocuments(“SortOrder”))
'SortCollection(Me.QuoteDocuments)
'SortCollection(Me.QuoteDocuments.Properties(“SortOrder”).Value )
Can you see what I am doing wrong? or if you could write an example that would be helpful too.
John
Solid Edge ST7
oops, just saw your example, will try it.
Solid Edge ST7
