cancel
How to Add Copy Prompt similar to Add prompt in Add/Delete/Copy Buttons
Hello All,
I am looking to Add copy prompt window which can popup for user to type the name to be copied to against the selected item from the subpart grid. By default RS takes its own naming convention during copy but we need to type specific name like we do for Adds in a Add prompt window.
I did not see option for Copy prompt as there is for Add prompt in Add/Copy/Delete button.
Narendra
Engineering Intent
Re: How to Add Copy Prompt similar to Add prompt in Add/Delete/Copy Buttons
Naren,
Under the 'When changed' tab of the Button boolean function just use the InputBox funcition.
Me.str_input = InputBox("Naren, Enter your data here please", "Inputbox", "", 500, 400)
Yuri
