How to return to RSEditModel after debug?
When ever I debug with a 'stop' statement in my Custom.vb, the control never really returns to the RSEditModel after I finish the debbug. Yes I'm using the external edit model toggle.
Any ideas on how to make this work?
Re: How to return to RSEditModel after debug?
This also happens to me some time. I don't know the solution but here's workaround that works for me:
i'm not adding stops in RS code and I'm not using RS Engineer "Debug..." context menu options. I just attach debugger(Visual studio) to RsEngineer.exe  and from it's leve I'm using Debug->New Breakpoint -> Function breakpoint and typing the name I need to stop on. (i.e for property formula it's Formula_MyPropertyName).
This way always works fine for me.
