How to select multiple parts in Grid to delete
Hello All,
We have a requirement to delete multiple parts at once by selecting in the grid view, by default we could only select one item in grid to delete.
Is there any way we can achieve multi-selection on Grid / anything else, as there will be many items to delete and standard delete process takes 3 clicks, i.e, Right click on required item on grid and click delete and press OK or we could make it 2 clicks by adding a delete button on screen but however it will take lot of time if there are 100's of parts to delete.
Narendra
EngineeringIntent
Re: How to select multiple parts in Grid to delete
I had a talk with our colleague Thilak and he gave a workaround by placing a check box in first column of the grid for multiple selection of items and having a button to delete the selected check box.
Narendra
Engineering Intent
nice solution !
