Images in Thin Client Not Appearing?
I got the Thin Client (8.11.1) running in chrome on my local machine (Win7x64) for a demo, but my images (png or jpg) aren't showing up. I inspected the source code for the image in Chrome and tried placing the image file in the href tag location, but no dice there.
I'm not sure where to look. Is that what the Apache Tomcat service does?
Re: Images in Thin Client Not Appearing?
Siemens Genius Siemens Genius
Siemens Genius
Are there any space or funny characters in the filename of the image?
Not too funny. Smiley Wink
I tried changing it to Banner.png, same problem.
Siemens Genius
I was hoping for a simple solution. Spaces and funny characters cause problems sometimes. Also, subfolders work for the rich client but not the thin client.
Unfortunately, the filenames look OK. Are these images coming from WIP or MasterDocs?
No sub folders, it's in MasterDocs.
Siemens Genius
It appears that something in Tomcat 7 is no longer compatible. We'll update the system requirements to state Tomcat 8 or above is required.
Just to confirm, upgrading to Tomcat 8 solved your problem?
Yes, I updated to Tomcat 8.0.36 and it's working correctly now. I'm not sure if it was actually an issue with Tomcat 7, or if I messed up the install on 7 and did it right on 8. Either way, it's working now.
Thanks Rick.
