Is it possible to give a user read only access to an application in Rulestream Engineer
Question from a customer. He says:
"I saw an option for this under Tools | User Permissions but it doesn’t seem to do anything"
Gene
Gene Libardi
Principal Solutions Architect
Engineering Intent Corporation
www.EngineeringIntent.com
Re: Is it possible to give a user read only access to an application in Rulestream Engineer
Hi, Gene.
It does.
User Yuri has FullAccess.
User Yuri1 has ReadOnly access to the TEST and he can not run the line item. He can't create a line item. Yuri1 is albe to review the project from RSArchitect but not able to create/delete properties and do any other changes.
If access permissions level set to 'None' - user can't even view the application in Architect.image.pngno permisions.GIF
the weird thing is that Yuri1 can Delete the lineitem created by Yuri (if it is not checked out)
