Move Face
In a Solid Edge spec I'm attempting to drive the location of a Move Face command.  I have attached the file.  Is this Supported?  In the spec only the Length varaible will be pushed into the part from Rulestream.
The Move Face does not show up under Features in the spec.
Betreff: Move Face
Siemens Genius Siemens Genius
Siemens Genius
Is it possible to associate the length to an expression and drive this?
BR
Chrisitan
Re: Move Face
Builder
Builder
Hi EI-JustinRice,
Currently FaceMove feature is not implemented in RS-SE integration. In RS; scanning variables from variable table so you can use that for changing the distance.
Have you tried that?
Onkar
