Multiple lines in Tooltip
In the description portion of the UI visible properties, I entered information in multiple rows. However, it all shows up as one long line when viewed as a Tooltip on the UI in engineer.
Example
Description appears as:
"Document References:
H-XXXXX
IS-XXXXX
D-XXXXX"
Tooltip appears as:
"Document References: H-XXXXX IS-XXXXXD-XXXXX"
Is there a way to display the Tooltip in multiple lines as it is viewed in the description box of the property?
Sam
