NX Drawing Filename
Does anyone know the naming scheme for NX drawing filenames ? It seems to be <BASENAME>-(<PROJECTID>-<LINEITEMID>-<?????>).prt
I'm missing the 5 digit number at the end. For normal NX prt files it's the object ID of the part family instance, which happens to be 4 digit and constant. But for the drawings it seems to change for each release. The drawing that I want to automatically refer to is generated by the same NX spec as the part.
Attached a picture of the geometry spec tab. For the part I can change the naming on the "Additional Attributes" tab, for a drawing I can't find such thing.
