NX Drawing table (tabular note) automation by Rulestream
Working in the GA drawing Automation by Rulestream found difficulty updating weight table for all the components in assembly, Numbers of components are numbers of rows in table which is going to decide depend on the configuration we select. Please suggest me, How to update this table in runtime by Rulestream or NX?
Re: NX Drawing table (tabular note) automation by Rulestream
Siemens Genius Siemens Genius
Siemens Genius
Hi Hasolev,
can you please provide some more background in what you are doing? Which is the version you are using? Managed Mode? This would help a bit to better understand what you excatly wnat to do.
Best Regards
Christian
Hi Christian
I am working on NX 8.5, Rulestream 8.11.0 version and no managed mode.
My basic requirement is to create automatic table (tabular note) in NX
Drawing where the number of rows are depend on the component list in
dynamic assembly by Rulestream.
As in Rulestream, Assembly configuration changes which leads to change in
the component list and that I need to reflect in to the NX Drawing for
updated component list and their weights.
[image: Inline image 2]
-- Thanks & Regards-
Vinayak Hasole
Hi Christian
Vinayak Hasole
Siemens Genius
Hi Vinayak,
I would prefer using the NX functionality “Insert/Table/Part List…” If a components comes in, it will be reflected automatically in the table on the drawing.
If you need some help with preparing this ... I could help.
Best Regards
Christian
