Properties window disappeared
The Properties window disappeared in Rulestream Engineer build 8.12.0.7556.
Is there a setting to restore it?
John
Rulestream ETO Version 8.12.0.7556
Solid Edge ST7
Re: Properties window disappeared
Just found the answer. Right click root and edit processes, select User Interface tab, select 'Show the Property List' .
Solid Edge ST7
