Property User interface
on the user interface tab of a property, if Enabled is unchecked it seems you can put a formula in but I cant get it to work,
If Me.property1 >= 250 Then
	Result = status_enabled = False
Else
	Result = status_enabled = True
End If
it passes the syntax checker but I am just guessing, can anyone provide any examples?
cheers
Re: Property User interface
It seems your code must be changed a little bit:
	Result  = False
Else
	Result  = True
End If
thanks
You are welcome Smiley Happy
