Rulestream.INI setting for SolidWorks Version
How do I determine the correct "SldWorks.Application.xx" version for the Rulestream.ini key SolidWorksVersion?
Re: Rulestream.INI setting for SolidWorks Version
I believe what you are looking for can be found from https://en.wikipedia.org/wiki/SolidWorks under the Release history Version. ie. 2016 should be 24.
