RulestreamModelServices - Apply an input xml to the RS model.
Hi Experts,
With RSEngineer we could do something like this to preload all settings
"D:\Program Files\RuleStream 8.12.0\RsEngineer.exe" /PROFILE TR_mm /XMLIN "D:\EI\transfer_Format.xml"
Is there a way to achieve the same with RulestreamModelServices API? Instead of setting individual properties on part families, can we pass in an xml file with all properties set?
-Thilak Rao
