Show Call out or Balloons from BOM Table in SE Drawing
Is there a way to create a BOM table on a SE drawing template that is associated with ballons that point to geometry that may be dynamic in the model (come, go, move, etc.) Are BOM tables with callouts possible at all with SE and RS?
Gene
Gene Libardi
Principal Solutions Architect
Engineering Intent Corporation
www.EngineeringIntent.com
Re: Show Call out or Balloons from BOM Table in SE Drawing
Builder
Builder
Gene,
In Rulestream Solid Edge integration there is no way to create BOM table.
OnkarP
PLM World Member Genius PLM World Member Genius
You might be able to have the Parts List in your draft template file with settings for auto-balloon.
