Show only part of Model in drawing view (SE)
In Rulestream using Solid Edge, is there a way to only show some of the model in a drawing view, rather than the entire model?
Gene
Gene Libardi
Principal Solutions Architect
Engineering Intent Corporation
www.EngineeringIntent.com
Re: Show only part of Model in drawing view (SE)
Gene,
There is no support for showing only some of the components from model in the drawing view using Rulestream Solid Edge integration.
Drawing "Layer" is workaround for hiding and showing contents in the drawing view.
OnkarP
Can you clarify this a bit? Are you saying that I can put geometry in my
assembly on different layers, and then tell a view on the drawing to only
show certain layers? How would I do that?
Gene
Gene Libardi
You can create a drawing with required views. Add contents of views(Geomtric contents or annotations) in layers. Scan the file in RS-SE integration and in Runtime(RsEngineer) using layer "Show" property hide or show the layers.
-OnkarP
Hi I have the same question as the OP, can you expand on the "Add contents of views(Geomtric contents or annotations) in layers" part.
How do you add an assembly with its parts on different layers?
Steve
