The NX drawing table property does not work
Hi all,
I would like to create a generic table on a drawing and also change its size, change the cell content and so forth.
I can create the table in the drawing spec, but when I run the application, the table is not created.
In the second picture I had Rulestream create the properties automatically to make it simpler and the syntax would be correct as well.
