Changing the Case of a Property Value
Community Manager
Add the following to the When Changed formula of a string property to change the case of the characters. The change does not occur during entry, but after.
Example (ToLower):  When a user enters Abcde and moves to a different field or process step, the value of that property changes to abcde.
     Value = Value.ToLower
Example (ToUpper):  When a user enters Abcde and moves to a different field or process step, the value of that property changes to ABCDE.
     Value = Value.ToUpper
NOTE:
  •  This is for Input Properties only
  •  For formulas use:   result = String.ToLower(result) or result = String.ToUpper(result)
