cancel
Exporting XML Programmatically
Community Manager
The following explains how to programmatically create an XML from Rulestream Engineer to simulate a user choosing “Model -> Export XML” from the menu.
ObjectManager.SaveXML Method (String, Int32, String, String, Int16, Boolean) saves the information required to rehydrate this model into XML
Namespace:  RuleStream.Kernel
Assembly:  Kernel (in Kernel.dll)
Syntax
 Public Function SaveXML ( _
        strProject As String, _
        lngLineItem As Integer, _
        strComment As String, _
        strXMLFile As String, _
        intSaveMode As Short, _
        TestMode As Boolean _
) As Boolean
Parameters
strProject
  • Type: String
  • ProjectID to put into the Model node (can be used to specify a recommended ProjectID to use at load-time).
lngLineItem
  • Type: Int32
  • LineItemID to put into the Model node (can be used to specify a recommended LineItemID to use at load-time).
strComment
  • Type: String
  • Comment to be put into the Model node.
strXMLFile
  • Type: String
  • Filename (and path) to save the XML file to.
intSaveMode
  • Type: Int16
  • [Optional] The number of levels down the Model to save. Passing -1 forces all levels to be saved, not just the properties with overrides.
TestMode
  • Type: Boolean
  • [Optional] Set to True to denote test mode.
Return Value
status as Boolean [True = success]
Contributors
