How to step into a process step with custom.vb
Community Manager
Place the following line within your custom.vb where you need to jump to a specific process step, replacing,  YourProcessStepName, with your name of your process step in quetion.  An example might be when you need to create the CAD model before stepping into other processes when running via Unattended Engineer:
SetProcessStep("YourProcessStepName", rootpart)
Note: The SetProcessStep function loops through all process steps
Then elsewhere in the custom.vb place the following code:
    'Function that finds a specified process step and returns the object
    Private Sub SetProcessStep(ByVal sproc As String, ByRef epart As Part)
        'selected process step
        Dim sProcessStep As ProcessStep = Nothing
        'loop through all procesteps, find the process step passed by sproc
        For i As Integer = 1 To RootPart.ProcessSteps.Count
            Dim oProcessStep As ProcessStep = CType(RootPart.ProcessSteps.Item(i), ProcessStep)
            If oProcessStep.Name.Contains(sproc) Then
                sProcessStep = oProcessStep
                Exit For
            End If
        Next
        g_RsEngineer.SelectProcessStep(sProcessStep, epart, -1, 0)
    End Sub
