How to submit a Knowledge Base article
Community Manager
Hi Tony,
How can I create an entry to the knowledge Base area? I'm quite sure that there are users who would like to spread their experience.
Best Regards
Christian
The process is:
1. Sign in as a registered user
2. Create a new Forum article
3. Under the "Option" item (Upper-right) of the article . . .
4. ... Select "Nominate to Knowledge Base"
tkb.jpgNumbers correspond with the numbered process stepsNumbers correspond with the numbered process steps
I will receive a notification that a Forum article has been nominated for creating a Knowledge Base article.  I then review, edit and post.  As the nominator you receive credit for the contribution.
Note:  You may also [Post a Comment] to a Knowledge Base article.  It too will be reviewed and then added via a revision.  You receive credit for these submissions as well.
- Tony
