How to use SQL Server Express with a hardcoded port
A user wanted to add a SQL Server Express instance on a server that already had SQL Server installed, and they wanted to use a hardcoded port address, like:
MyServer,1435\SQLEXPRESS
First thing to note is that above is the way to refer to that SQL Server instance from both SQL Server Management Studio and the Rulestream Options dialog, using a comma instead of a colon (as you would expect) to denote the port number:
<serverName>,<portNumber>\<instanceName>
Second thing to note is that configuration of how to specify a different port is a little tricky in the SQL Server Configuration Manager.  The information at this StackOverflow post is helpful:
https://stackoverflow.com/questions/11278114/enable-remote-connections-for-sql-server-express-2012
With that, everything worked wonderfully!
