Prevent CAD performance issues
Community Manager
As we continue to add support for newer versions of the CAD systems we remind you that when you upgrade your CAD system you should also update your existing MasterDocs CAD files to the newer version.  Failure to do so will result in performance degradation as the CAD system will be updating the files on-the-fly every time they are opened from MasterDocs.
Most CAD systems have a utility that will perform this upgrade across directories and sub directories.
Google or ask your CAD reseller for assistance if you’re unable to find the utility.
If all else fails simply open each file in MasterDocs using the newer CAD version and then resave.
