Sending Email from within Rulestream
Community Manager
To send email using the SendEmail subroutine, place the following code in custom.VB.
    Public Sub SendEmail()
            Dim message As New System.Net.Mail.MailMessage("", "", "Subject", "BodyText")
            Dim emailClient As New System.Net.Mail.SmtpClient("")
            'use the next 3 lines if your smtp server needs authentication else comment them out
            Dim SMTPUserInfo As New System.Net.NetworkCredential("myself", "mypassword", "mydomain")
            emailClient.UseDefaultCredentials = False
            emailClient.Credentials = SMTPUserInfo
            'use the next 2 lines to attach any files else comment them
            Dim attachFile As New System.Net.Mail.Attachment("C:\Attachment.GIF")
        Catch ex As Exception
            MessageBox.Show(ex.Message, ex.Source, MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
    End Sub
Use the following code to send an Email from Exchange:
To use the signature you need to create a signature called Siemens (in this example). The email will be sent as HTML. If you don’t want HTML delete the signature section and change .HTMLBody to .Body
Public Sub SendMail(ByVal Subject As String, ByVal Bodytext As String, ByVal Recipient As String, Optional ByVal Attachment As String = "File as Attachment")
            '--- Check whether the Outlook process is running
            If Process.GetProcessesByName("outlook").Length > 0 Then
                '--- evrything is fine don't do anything ---
                '--- start Outlook  ---
            End If
            '--- initalize Outlook ---
            Dim objOutlook As Object
            Dim objOutlookMsg As Object
            Const cMailItem = 0
            '--- if needed please uncomment ---
            'Const cBCC = 3
            'Const cImportanceHigh = 1
            'Const cCC = 2
            Const cTo = 1
                                             '--- get Signature ---
                                             Dim appData As String = Environment.GetEnvironmentVariable("APPDATA")
                                             Clipboard.SetText(IO.File.ReadAllText(appData & "\Microsoft\Signatures\Siemens.htm", System.Text.Encoding.Default))
                                             Dim mySignature As IDataObject = Clipboard.GetDataObject()
            '--- create object ---
            objOutlook = CreateObject("Outlook.Application")
            objOutlookMsg = objOutlook.CreateItem(cMailItem)
            '--- create mail ---
            With objOutlookMsg
                Dim objOutlookRecip As Object = .Recipients.Add(Recipient)
                objOutlookRecip.type = cTo
                .Subject = Subject
                .HTMLBody = Bodytext & CType(mySignature.GetData(GetType(String)), String)
                'If Attachment <> "File as Attachment" Then .Attachments.add(Attachment)
                '.Importance = olImportanceHigh 'If needed please uncomment
                .Display() ' Display() shows mail, .Send() sends directly
            End With
            '--- destroy object ---
            objOutlookMsg = Nothing
            objOutlook = Nothing
            '--- Catch error if Outlook is not installed ---
        End Try
    End Sub
