Do you mean
Using SQL to Query the Rules, Project, and Component Databases
by Community Manager Community Manager on ‎04-18-2016 11:32 AM
These are connections to the Rules, Project and Component databases used to access data within these databases via a formula:
  g_RulesData.ExecuteSQL( SQLstring )
  g_ProjectData.ExecuteSQL( SQLstring )
  g_ComponentData.ExecuteSQL( SQLstring )
Here is an example of code that would be placed in the custom.VB to access data in the "partValue" column in the Component database of an application
Try
          Dim strSQL As String
          strSQL = "SELECT partValue FROM AppsDimensions WHERE partPlating = '" & strPlatingType & "'"
          '-- Execute the SQL against the component database
          Dim ds As DataSet = g_ComponentData.ExecuteSQL(strSQL)
          '-- Make sure at least 1 result set was returned
          If ds.Tables.Count > 0 Then
                   '-- Loop though each row in the first result set
                   For Each dr As DataRow In ds.Tables(0).Rows
                              '-- Access a column value by name
                              result = CDbl(dr.Item("partValue"))
                   Next
          End If
Catch ex As Exception
          g_ObjectManager.LogError("getPartValueSQL", String.Format("Error: ""{0}"" .", ex.Message), MsgBoxStyle.Critical)
End Try
Contributors
