cancel
Area Properties 2D st6 not working with 'fillet' elements
N/A
Hi. believe this is a bug.
Wanted to advise ASAP. Does this now get to the people that matter at support?
Regards.
edit. sometimes it works, and then it doesn't so perhaps i have some corrupt geometry. I notice the principle axis and other references go wildly outside the geometry. Something wrong somewhere. Once it has happened, even simple other profiles with fillets just don't work.
Re: Area Properties 2D st6 not working with 'fillet' elements
Community Manager
Can you post an image of a case with bad results. It will help recrete something to send to development.
Rick B.
