CURSOR READOUTS GETTING BLOCKED
Since I’ve installed ST7, I’ve had a problem with the alignment lines and read outs from the cursor position interfering with full visibility of the read outs. I’ve played around with the Intellisketch cursor settingS without any positive result. The below website shows a video of what I mean. I have a Windows 7 PC with 8 Gb of RAM. http://screencast.com/t/DAda0jl4 Thanks, Ron
Re: CURSOR READOUTS GETTING BLOCKED
This topic has been posted for awhile now and I've got no response.  Why?
Ron
Esteemed Contributor
Hi Ron,
Probably because not many other users have that much displayed info, so doesn't have the same affect.
Community Manager
Ron,
You are refering to the Grid Readouts. Correct? There was a display change in ST7 to resolve the flickering problem in ST6 with the grid readouts in the 3D environments. This change caused the regression you see where the offset from the cursor was not maintained. A PR will be created to resolve this issue.
Rick B.
Sean, I admit to having a lot of info.  I guess I haven't adapted yet to the added readouts since ST7.  But never the less, it should be readable.  And as Ricky points out, a PR will be issued.
Ron
Ricky, thanks.  I'm not familiar with what a "PR" is but assume that is a software update.  If so, I guess it won't help us 2D users, right?
Ron
Community Manager
Ron,
A PR is a Problem Report. It is a mechanism by which problems are reported and documented. Development then uses the PR to make fixes related to the reported problem. Once fixed, the PR must be tested. At this point it can be closed as fixed.
Rick B.
