Reply
CUSTOM COLOR EDITING
In searching for the right color for whatever (e.g., grid lines), I've created several
different colors thru trial and error which than are called User Color #?'s. Some
others I've actually named. I'm about to reset SE back to the original settings
via Registry Editor.
First, I would like to find out the red/green/blue numbers for the "keeper" colors
so I can duplicate them after I reset? It seems that once a nonstandard color has
been used or set, you can't go back and edit it.
Also, as a matter of housekeeping, I would like to know if there is a way to delete
unwanted User Colors in the future when this happens again?
Ron
Ronald W Latour
