Reply
Can't install Free2d!
Whwn I try to install free2d the installwizard report that I already have an SolidEdge
software installed already.
I did have free eDrawings installed and therefore I removed the prog. restarted
the pc and tried to install Free2d again.
No luck this time either!
Searched the disk and registry and the only file I can find named Solidedge is an
solidedge.dll file belonging to Mastercam X and is used to convert files when importing
Solidedge-files to Mastercam X.
Anyone have an answer for this please?
Dag Kristiansen
Re: Can't install Free2d!
Dag,
Make sure you do not have the free Solid Edge Viewer installed either. If you are
sure you have removed any Solid Edge products you may have installed, I can send
you a tool that will clean any Solid Edge remnants from the registry and you should
be able to install the software. Let me know if you need this tool.
Rick B.
Do you have any other UGS / UG software installed? If not, try going into your registry
and looking for "unigraphics" and removing any instances.
>an SolidEdge
>is an
>importing
>Dag Kristiansen
